I am analyzing the requirement for emergency high rate depressurization using blowdown system for hydrocarbon system. The system will surely require emergency blowdown facilities in case of fire to cater for the need to protect the vessels from BLEVE and drive the process to safe conditions by depressurizing the source causing fire escalation.
Comparing the impacts of vessel rupture to piping system's rupture, API 521 code discusses that pipe ruptures can be more tolerable than vessel rupture specially due to the fact that vessel's failure impact area is much stronger than the case of the impact area of a pipe rupture. Also, because vessels will be more susceptible to be engulfed within fire than piping.
Accordingly, for a system of piping manifolds partially being on grade level while the majority of the piping go to pipe rack of height above the typical fire height from the base of the pool fire (8 meters), does any foresee the requirement for emergency blowdown system or would relying on firefighting and deluge system would be considered safe for a fire scenario?
