is it normal practice to install a restriction orifice upstream or downstream of a valve to flare? any preference on reasons why?
Restriction Orifice To Flare
Posted 06 December 2018 - 12:07 PM
Posted 06 December 2018 - 12:20 PM
Upstream or downstream of which valve?
If to be installed downstream of a valve, say a BDV, it's placed there to control the flow toward flare...
Posted 06 December 2018 - 12:32 PM
i have a blowdown valve and then an isolation ball valve to flare. yes the RO will be placed downstream of the blowdown valve, but in regards to the isolation valve, should the RO be placed downstream or upstream of the isolation valve? are there maintenance concerns w/ RO?
Posted 06 December 2018 - 12:39 PM
It is normally placed upstream of the isolation valve mostly due to necessity of RO maintenance/replacement...
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
Back Pressure Of Elevated Flare Vs Ground FlareStarted by Guest_Sid__* , 04 Jan 2024 |
Floating Closed Drain Drum With FlareStarted by Guest_Falah_* , 26 Jan 2024 |
Low Molecular Flaring (H2 Rich Flare Gas)Started by Guest_PKS_* , 23 Dec 2023 |
Pressure Control Valve Relief To Flare Upstream Block ValveStarted by Guest_Glauco_Tirollo_* , 07 Dec 2023 |
