1. The problem statement, all variables and given/known data
I am required to obtain the following
1) Energy targets and pinch temperatures
2) Composite Curves
3) Grand Composite Curve with and without utilities?
4) What utilities are you going to use to fulfill the energy targets? Why have you selected these utilities?
5) Design a HEN that fulfills the energy targets
6) Design a HEN that fulfills the minimum total costs
7) What is the difference between the two HEN designed
2. Relevant equations
http://publications....text/142245.pdf
This link contains the process description.
3. The attempt at a solution
I am not expecting anyone to read 60 pages, but there is part of it which is of relevance to me in solving the problem that is the process description. I am not confident in my understanding of the process and how the streams get heated to their target temperatures from just looking at the process flow diagram.I am using ASPEN Energy analyzer software to design a Heat exchanger network drawing both composite curve and Grand composite curve based on the stream data. In drawing the hot and cold composite curves we should not take into account the utility streams and from the data I cant figure out which is which?
Edited by AAAIK, 08 December 2018 - 09:21 AM.
