Flow Element Bypass Function
Started by nasr91, Mar 20 2019 09:17 PM
Posted 20 March 2019 - 09:17 PM
Dear all,
In unit I recently joined I noticed theee is a bypass of the nitrogen flow element at the BL of the unit and I wonder what the function of this anf when to use. The flow element is an orifice plate. Also it is the only header to have this bypass line.
Posted 20 March 2019 - 11:06 PM
hi ,
May have to do with higher demand , let say start up ?
my 2 cents
Posted 21 March 2019 - 12:34 AM
You are right I found a note on this bypass manual valve but then why doing this only with nitrogen why not on IA or any other header with orifice plate flow element.
Also what the benefit from bypass the orifice at the high demand?
And thanks sir for your replay
Edited by nasr91, 21 March 2019 - 12:36 AM.
Posted 21 March 2019 - 02:09 AM
hi ,
Save time ……… during specific operation , let say inerting a large volume for example .
Posted 21 March 2019 - 06:07 AM
Ok. Thanks alot for your help.
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
Firewater Theoretical Vs Actual FlowStarted by Guest_stu_* , 25 Feb 2024 |
