Safety Relief Valve Vent
safety relief valve vent type
#1 srktalasila
srktalasila
  • 5 posts
Posted 22 March 2019 - 04:08 AM
Dear all,
Shall we provide goose vent to the down stream of any safety relief valve if the tank is located outside the building. I could not find any details in API 2000 standard about which type of vent needs to be provided.
Can you plz help me in this doubt.
SRK TALASILA
  • 6,340 posts
Posted 22 March 2019 - 04:24 AM
Consider this ppt , you should get your answer .
good luck .
#3 fallah
  • 4,952 posts
Posted 22 March 2019 - 12:08 PM
You did try using API 2000 to find the detail of vent downstream of the PSV on a tank, hence appears the tank is atmospheric or low pressure one.
If so, the PSV can be "end of line" type and directly send the vented gas/vapor to the atmosphere if that gas/vapor isn't flammable or toxic otherwise the PSV should be "in line" type and the PSV outlet should be piped away to a safe location.
