I have a vessel vapor outlet where there are over 11 elbows. the vapor from the vessel is only used during startup. do you see any danger for the number of elbows on a vapor outlet line?
Elbows
Started by Sara Owens, Apr 02 2019 09:23 AM
Posted 02 April 2019 - 09:23 AM
Posted 02 April 2019 - 11:47 AM
Sara:
Before considering if there is any "danger" in evacuating any vapor(s) from your vessel, do you have any problem in submitting a detailed sketch (preferably an isometric) to our members? This is engineering basic data that is sorely needed before discussing any opinions on this query. Your query is just excessively simple. We don't know:
- the composition of the vapor(s);
- the flow rate of the vapor(s);
- the size of the fittings (elbows) used;
- the length of the piping and fittings employed;
- the pressure in the vessel at startup;
- the destination of the evacuated vapor (to atmosphere?) and the pressure at the outlet of the vapor(s).
Please respond with the basic data so our members can study it.
Non Standard Jacket Pipe ElbowsStarted by Guest_stelu85_* , 05 Nov 2018 |
Ansi B39.19 Stainless Steel Piping - Wall Thickness Of ElbowsStarted by Guest_black friday_* , 24 Jul 2012 |
