I am filling out physical properties of a liquid for control valve. One of the fields requested is vapor pressure. How is vapor pressure determined on HYSYS. is that reid or true vapor pressure? i understand reid and true are taken from 37.8 C (100 F). is this the correct value used for the vapor pressure and reported for control valve data. In some instances, the reid and true vapor pressure is not calculated in HYSYS and is left blank even though i have 100% liquid. Can this value be manually calculated in HYSYS? i know my inlet pressure has to be greater than my vapor pressure to ensure there are no bubbles at the inlet of the control valve. Anyhow, i don't understand the reference of 100 F. shouldn't vapor pressure be addressed based on the inlet temperature of the control valve?
Control Valve Data
Started by Sara Owens, Apr 02 2019 02:44 PM
Can Anyone Provide Me The Reference Datasheet For Deluge Valve?Started by Guest_Radha Krishnan Siva Kumar_* , 16 Apr 2024 |
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
Valve Cv InputsStarted by Guest_QuantumEng_* , 01 Apr 2024 |
Pressure Control Valve Issues For Gsw LinesStarted by Guest_fahadazh_* , 29 Mar 2024 |
Answered
Vacuum Ejector Pressure ControlStarted by Guest_himanshu.ch_* , 19 Mar 2024 |
