Pump Sizing And Costing
#1 sharonlae
sharonlae
  • 5 posts
Posted 03 April 2019 - 03:26 AM
Hi
I would like to find out if there are any pumps in the industry catered for small increases in pressure (~2.5 psi)?
My fluid flow rate is 77 gpm.
Thank you.
Best regards,
Sharon Lam
#2 farid.k
farid.k
  • 384 posts
Posted 03 April 2019 - 03:43 AM
Hi
Thank you.
Best regards,
Sharon Lam
Dear Sharon, pump will work based on system pressure. i don't see any issue to get the pump. if you talk to pump vendor regarding to your requirement, they will give any pump that can give more then your requirement (flow and head). and when it come to actual (during operating), pump discharge pressure will be lower then your expectation as pump discharge pressure will be based on your actual discharge system pressure.
#3 Raman Ramanjaneyulu
Raman Ramanjaneyulu
  • 10 posts
Posted 03 April 2019 - 07:00 AM
What is the pump discharge pressure and flow rate?
The question you are asking is not clear for me, could you please elaborate?
Raman
#4 thorium90
thorium90
  • 1,073 posts
Posted 03 April 2019 - 07:41 AM
I think a small canned pump could reach this flow and pressure
Edited by thorium90, 03 April 2019 - 07:41 AM.
#5 gegio1960
gegio1960
  • 517 posts
Posted 03 April 2019 - 08:13 AM
Dear Sharon,
your request is very vague...but, I'm incidentally working on little pumps and I'd like to share with you the attached pump selection graph.
A pump of the BT-500 series could serve your scope....
Just to prevent comments, the 60 Hz series is also available ;-)
good luck!
Edited by gegio1960, 03 April 2019 - 08:17 AM.
