Api Standard 612 Data Sheet Symbology
9 replies to this topic
#1 alextor
alextor
  • 12 posts
Posted 17 May 2019 - 01:11 AM
DATASHEET STEAM TURBINE (Annex A )  contains cells  "TEMPERATURE °C (TT)".
Which means abbreviation (TT)?
  • 1,376 posts
Posted 17 May 2019 - 11:05 PM
The steam temperature changes as it passes through the turbine. The maximum steam temperature inside the turbine is at the inlet. I think TT indicates the steam inlet location -- called the 'trip and throttle valve' or 'throttle trip valve'.
#3 alextor
alextor
  • 12 posts
Posted 19 May 2019 - 10:34 PM
I can not agree.
For example, the abbreviation (TT) is used for steam "EXHAUST"
#4 Pilesar
  • 1,376 posts
Posted 20 May 2019 - 12:41 AM
Well, I could guess again. (Typical Temperature?) But perhaps you will find the answer and report back so I will know also. In my opinion, any information on a data sheet that is not clearly defined is a potential problem. Both the vendor and the purchaser need to understand the specifications alike so they can agree on expectations. Abbreviations can be especially troublesome since there is no single set of universally recognized definitions. I would not be surprised if real transactions between purchaser and vendor use a different data sheet containing something other than 'TT' as a modifier since this is apparently an unclear term.
#5 breizh
  • 6,334 posts
Posted 20 May 2019 - 01:23 AM
TT : temperature transmitter ?
my 2 cents
#6 thorium90
thorium90
  • 1,073 posts
Posted 20 May 2019 - 01:53 AM
Actually, alextor, why not just post a picture of what you see?
Won't it be easier to understand and interpret it rather than a whole thread of guesses?
I'm pretty sure you will get a straight answer if we all can just see what you have seen.
#7 alextor
alextor
  • 12 posts
Posted 20 May 2019 - 03:38 AM
I saw (TT) in the real data sheet.
my 2 cents
It would be strange. DATA SHEET requires mandatory measurement EXHAUST steam, AUXILIARY steam? Why?
Why is this required in the STEAM CONDITIONS section?
A good idea
https://drive.google...iew?usp=sharing
#8 thorium90
thorium90
  • 1,073 posts
Posted 20 May 2019 - 06:27 AM
Thanks for the upload. It does clear things up.
I believe it means Total Temperature; static plus the dynamic temperatures.
Edited by thorium90, 20 May 2019 - 10:05 AM.
#9 breizh
  • 6,334 posts
Posted 20 May 2019 - 06:39 AM
I believe it has to do with an energy balance (TT).
I have added a tool to support you for this kind of exercise.
.https://www4.eere.en...ol/equipTurbine
#10 alextor
alextor
  • 12 posts
Posted 20 May 2019 - 11:04 PM
AUXILIARY steam not involved in the energy balance, but has the abbreviation (TT)
I think this is the most reasonable conclusion.
But it looks like this is only an assumption
not confirmed by regulatory documentation
