Nucleate Boiling- Boiler
#1 krishna106738
krishna106738
  • 14 posts
Posted 08 August 2019 - 09:29 PM
Hi Team,
As I understood that for good heat transfer to occur we have to design boilers on basis of nucleate boiling regime.In general for nucleate boiling delta T is between 10-30 C .My question is it possible to have nucleate boiling at higher delta such as 180-200 C also.
  • 6,347 posts
Posted 09 August 2019 - 12:16 AM
hi,
Let you consider this resource .
Good luck.
#3 krishna106738
krishna106738
  • 14 posts
Posted 16 August 2019 - 01:42 AM
Hi Briezh,
Thanks lot for sharing the articles, which tells about operational issue involved when we move away from Nucleate boiling region for reboilers.
I have question regarding power plant oil/gas fired thermosiphon boiler,in which to we can see there will be high delta between hot side and cold side.So how do we have to manage the nucleate boiling delta T in those cases.
Krishna
#4 krishna106738
krishna106738
  • 14 posts
Posted 18 August 2019 - 05:58 AM
Hi Breizh,
Is there any articles or source where i can clarify or learn about this particular cases.
Krishna
#5 breizh
  • 6,347 posts
Posted 18 August 2019 - 06:16 AM
I cannot offer more . You may use the search engine in this forum and check for Thermosyphon .
If the Delta T is big , you may  vaporize the liquid with the consequences on the material (deterioration)
Good luck .
Edited by breizh, 18 August 2019 - 06:20 AM.
#6 krishna106738
krishna106738
  • 14 posts
Posted 18 August 2019 - 12:03 PM
Thank Breizh
#7 breizh
  • 6,347 posts
Posted 19 August 2019 - 10:54 PM
Consider the document attached , extract of Process heat transfer from D.Q Kern .
