2
Unit Conversion
#1 ChrisHughes
ChrisHughes
  • 12 posts
Posted 19 November 2019 - 08:15 AM
Natural Gas from the mass balance is in kg/hr, but I need to convert it to metres cubed at STP (reference not given).
How do I do this?
#2 Bobby Strain
  • 2,811 posts
Posted 19 November 2019 - 10:29 AM
It's not possible without knowing the molecular weight.
#3 MrShorty
MrShorty
  • 465 posts
Posted 19 November 2019 - 11:08 AM
In my experience with the gas industry, it seems that -- at STP (whatever that is) -- they just assume ideal gas at STP to convert from mass to volume. As Bobby indicates, this means first converting from mass to mole, but should otherwise be a straightforward calculation. Can we assume you are familiar with the ideal gas law (or other preferred EOS if your group doesn't want to assume ideal gas)?
#4 breizh
  • 4,470 posts
Posted 20 November 2019 - 04:25 AM
Define the standard condition , get the composition of your gas to calculate its molecular weight .
-If you assume its an ideal gas (Z=1)  , calculate the density thus the volumetric flowrate .
-You may want to use an EOS to calculate Z , then the density ,etc .
https://www.e-educat...520/m18_p4.html
https://checalc.com/...aturalgasZ.html
my 2 cents
Edited by breizh, 20 November 2019 - 09:09 AM.
