Reliability Of Isolation Valves For Flare Gas Recovery Systems
flare gas recovery fov buckle pin valve fast opening valve rupture disc
No replies to this topic
#1 Soothsayer
Soothsayer
  • 17 posts
Posted 02 December 2019 - 02:04 AM
Hello.
I would like to know if it is possible to install, in terms of reliability and safety, a Buckling Pin Valve (BPV) instead of a FOV (Fast Opening Valve) for isolation of a flare header when installing a Flare Gas Recovery System.
As a secondary layer of protection, assume that a rupture disc is installed in parallel to the isolation valve.
Regards.
