Hello every one, is there any standards or common practice which help in determining the need for fire and gas system for any equipment?. the problem is if we will install a small separator in receiving area which in in the fence of a facility but a far from any source of fire? is there a need for this equipment to be covered with gas and fire detector ? what are the factors that determine the need of this system , the size of the vessel , the inventory or the location of it?
Fire And Gas System Requirement
Started by mido, Dec 10 2019 03:07 AM
Posted 10 December 2019 - 03:07 AM
Posted 12 December 2019 - 12:44 AM
You should check for local regulation or contact your safety bureau or fire brigade ( based on my experience) .
my view
Posted 12 December 2019 - 01:07 AM
If there is a flange in the line or any rotataing equipmen, you should have a fire and gas detector.
Closed Drain SystemStarted by Guest_Falah_* , 26 Mar 2024 |
Compressed Air RequirementStarted by Guest_Mohamed cage_* , 14 Apr 2019 |
Lube Oil System For TurbomachineryStarted by Guest_bckesim_* , 03 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
Psv Fire Case Relief Load CalculationStarted by Guest_mahmooddalvi09_* , 21 Feb 2024 |
