MDEA is used in our refinery as an acid gas remover (CO2/H2/HCN ect..)
Recently we had an increase in ammonia in the MDEA and and decrease in MDEA strength. Adding MDEA did not increase the MDEA strength level. The Dilema is that we're not sure if the analysis is done correctly. Is ammonia interfering? The strength is determined by titration of lean MDEA with sulfuric acid. We tried to strip the ammonia by boiling the Lean MDEA but that did not increase MDEA strength significantly. The titration curve did not show any other inflection than that of the MDEA EP with H2SO4.
Any other idea how to determine MDEA strength in the presence of ammonia?
Mdea Strength In Presence Of Ammonia
Started by Peter A., Oct 09 2006 09:02 PM
No replies to this topic
Posted 09 October 2006 - 09:02 PM
Ammonia Evaporation Rate InquiryStarted by Guest_aslungaard_* , 30 Mar 2024 |
How To Select Reboiler And Condenser Operating Pressures For A Mdea ReStarted by Guest_Alexis Azamar_* , 27 Mar 2024 |
Need Help In Calculating Ammonia Slip In Scr Unit.Started by Guest_Redbull010203_* , 11 Mar 2024 |
Remove Water From Ammonia Aspen PlusStarted by Guest_fmalik_* , 12 Feb 2024 |
Simulating Solubility Of Ammonia Gas In WaterStarted by Guest_abdullahq7_* , 30 Jan 2024 |
