Shell And Tube Heat Exchanger Design
Posted 19 June 2020 - 12:23 AM
Posted 19 June 2020 - 04:34 AM
My two cents:
Use the software HTRI/Aspen or do hand calculation.
If you don't have the softwares or do not want to do the hand calculation, then delegate this work of Thermal Design to the vendor. I am suggesting this because you cannot blindly rely on an unapproved, unvalidated excel sheet
Posted 19 June 2020 - 08:39 AM
Edited by Jaldhipatel, 19 June 2020 - 08:39 AM.
Posted 19 June 2020 - 09:00 AM
To get a proper answer you should supply more information about your application !
You may use this calculator to support your work or any text book related to heat transfer ( Kern is a good one )
http://www.engineeri...ng/thermal.html
Posted 20 June 2020 - 12:06 AM
I just want some simple format of excelsheet to design shell and tube heat exchanger. I'm already aware with designing of s&t HEx but i want to do it with help of excel as i want to submit it.
Posted 20 June 2020 - 01:09 AM
I would suggest you to prepare an excel draft with your starting data/ideas and to submit us for comments, improvements, clarifications...
maybe we understand better... and you could learn something.
good luck!
Posted 20 June 2020 - 01:28 AM
As gegio was pointing out , we are here to support your work . Don't expect us to perform your task . Let us know your difficulties and for sure someone will review your work .
A bunch of literature are attached underneath . Another resource could be the search engine in this forum .
Engineering is always hard work .
Edited by breizh, 20 June 2020 - 09:02 PM.
Posted 20 June 2020 - 09:18 AM
Thank you i am trying using HTRI but i want to do hands on calculation also so if there any simple excelsheet which i can follow for that then it will help me.
If you have HTRI then why do the hand calculations unless you are a fresher. The way you can alter the dimensions and get results in HTRI would be difficult by hand calculation.
Also, you need to check for the vibration analysis, that would be easier in HTRI.
Posted 20 June 2020 - 09:23 AM
#10
Posted 20 June 2020 - 11:05 AM
#11
Posted 20 June 2020 - 06:35 PM
Did you check for HTRI manual ?
Another option , let you use your favorite search engine and key in : "HTRI tutorial " , you should find links and videos about HTRI .
https://www.google.c...chrome&ie=UTF-8
Edited by breizh, 20 June 2020 - 06:36 PM.
#12
Posted 22 June 2020 - 01:40 AM
Also, you can go through the TEMA Standard for heat exchangers. You will get all sorts of guidelines over there
#13
Posted 22 June 2020 - 04:51 AM
Look up vendor datasheets for LNG Shell and Tube vaporisers to give you an indication of what sort of duty / size would be required.
What is your heat source? Water? Seawater? Steam? Mixed refrigerant? BOG?
Cryogenic shell and tubes have various unique conditions that need to be considered, e.g. ice growth, expansion/contraction etc.
To be blunt, if you want it to be easy and not time consuming, you need to know what you are doing on it.
#14
Posted 25 June 2020 - 02:04 PM
THANKS IN ADVANCE
#15
Posted 26 June 2020 - 05:33 AM
It means you have that number of units operating in parallel - the total flow entered is divided equally between each unit.
If you want to reduce the number of units in operation, you will probably need to make the exchangers larger. it would depend on the impact that results from the increase of flowrate to each unit, the amount of surface area overdesign you had previously, etc.
#16
Posted 28 June 2020 - 07:56 AM
I got (0.95) vapor fraction in outlet not 1 so what's problem behind this anyone have idea. I done many trial and error to resolve it but it couldn't.
#17
Posted 28 June 2020 - 09:41 AM
It's not completed then.
What are your process details?
What does your current design look like?
Is it below or above the critical pressure for the mixture?
Have you specified tube inserts?
https://www.htri.net...-critical-point
They will help you as well.
#18
Posted 28 June 2020 - 10:29 AM
Hot fluid cold fluid
In 90 C In -156 C
Out 12 C out 0 C
Op.pre 2.5 barg 90 barg
I got around 650 tubes with around 10 m lenth and 19.05 mm dia and 18.9 MW heat duty.
#19
Posted 28 June 2020 - 10:30 AM
#20
Posted 29 June 2020 - 09:00 AM
18.9 MW - so around 100 tn/hr of LNG based on your inlet / outlet temps.
At this size, I would assume it is a straight pass BEM style unit.
What is the shell ID?
What baffle type?
Shellside skin temperatures?
#21
Posted 30 June 2020 - 07:19 AM
Hot fluid (GW 36% w/w)
In 90 C
Out 12 C
Flow 54.91 kg/s
Cold fluid (LNG)
In -156 C
Out 0 C
Flow 24.76 kg/s
Heat duty 16.5 MW
Design And Fabrication Of Reflux DrumStarted by Guest_Femi_* , 22 Apr 2024 |
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , 19 Apr 2024 |
Overall Heat Transfer CoefficientStarted by Guest_T_bag_* , 16 Apr 2024 |
Specific Heat DatabaseStarted by Guest_bckesim_* , 08 Apr 2024 |
