Lng
Posted 20 June 2020 - 04:53 AM
Posted 20 June 2020 - 05:21 AM
Regarding vaporizer you should contact vendor familiar with this type of application , a link is attached .
Different set up are available , scroll the menu .
https://www.chartind...-Air-Vaporizers
For properties , you are the one who is the supposed to know the material and composition , if not ask for a COA or specification .
http://www.liquefied...er.com/LNG.html
https://aip.scitatio....1063/1.5093800
note : Go to number 14 ( excel sheet)
To me you should prepare a spec sheet and submit to vendor .
Edited by breizh, 21 June 2020 - 09:59 PM.
Posted 25 June 2020 - 07:56 AM
Posted 25 June 2020 - 08:13 AM
I would follow Breizh's advice, in order to obtain accurate values you must know LNG composition, then accurate models such as for example GERG, will allow to calculate the properties.
