Need Help Hysys Output Blend
hysys oil refining hysysoilmanager oilmanager blending
#1 Moctezuma17z
Moctezuma17z
Posted 21 February 2021 - 11:38 PM
I have a couple questions, i'm barely know how hysys works but i need to use it for some stuff that i need to do, so,
1. For add an assay data that i have (TBP and some bulk props like API, KUOP and viscosity, thats it) which components do i should use to add in the components list, I did a test with some components for the list that i´ve seen in some youtube tutorials
I dont know how this influence in the assay, but ok, thats my first question
2. For the output blend i have to add 2 oils from my input assay, thats clear for my. but, do i have to do something else or thats it?
I mean, add the output blend, i select 2 oils from my input assay, then i have to decide the flowrate and then i can see the TBP Plot of the mixture, thats it? looks to easy or idk, my knowing on thys aspen hysys program is very very beggining, so i need some answers, please.
All i want to do is an oil blending for two crude oils, with some assay data that i have at diferent flowrates, thats it
#2 SilverShaded
SilverShaded
  • 237 posts
Posted 22 February 2021 - 03:58 AM
Yes, just mix them and plot the result.  Check the plot of each individual stream is correct first.
