Is recirculation creates vaccum in vessel ?
Circulation
Started by Jaldhipatel, Jun 14 2021 12:12 AM
Posted 14 June 2021 - 12:12 AM
Posted 14 June 2021 - 07:25 PM
Can you explain what is the matter, process conditions, fluids and P&ID or process diagram.
Horacio
Posted 15 June 2021 - 03:13 AM
We have simply a reaction vessel in which we create vaccum to absorb gas. Since the gas is at high pressure not much vaccum needed in absorption side so we use pump and circulate absorbing fluid no venturi in line only packing columns and then vessel..so does circulation of fluid in packed column create vaccum in gas nozzle..?
Posted 15 June 2021 - 06:31 AM
It depends. please attach P&ID or PFD. We need to see how the venturi is used.
Presence Of Circulation Vents On The Fixed Roof Of An Internal FloatinStarted by Guest_Vegeta_* , 12 Feb 2023 |
Teg Circulation Pump Have Cavitation IssueStarted by Guest_rizwangoheer_* , 04 Jul 2022 |
Circulation Rate In Refrigerated Storage TanksStarted by Guest_Vegeta_* , 20 Jun 2022 |
Centrifugal Compressor Stage Internal Circulation Flow EstimationStarted by Guest_Said Salim_* , 16 Oct 2018 |
Answered
Question About Glycol Circulation RateStarted by Guest_Mohamed Selim_* , 26 Dec 2016 |
