Pump
Started by Jaldhipatel, Jul 05 2021 05:33 AM
Posted 05 July 2021 - 05:33 AM
Hello..if pump rotates in opposite direction then what happens to pump ? And what cause pump to rotate in opposite direction ?
Posted 05 July 2021 - 07:20 AM
Why this question ?
Risk for the impeller to be unscrewed . There is an arrow on the body of the pump indicating the direction .
Electrical connection should be performed by E.I electrician or Engineer .
note : this is very basic .
Posted 05 July 2021 - 08:05 AM
The impeller could jam with damage to the pump seal and bearing...
One of the main cause leading to pump rotation in opposite direction is wrong wiring...
Vacuum Pump Power EquationStarted by Guest_hysyshunter_* , 22 Apr 2024 |
Heavy Crude PumpStarted by Guest_Rahimzadeh_* , 13 Apr 2024 |
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Piping Design_ Pump PipelineStarted by Guest_anh.phungthai@boydensvn_* , 29 Feb 2024 |
Design Considerations For Cryogenic Submersible PumpStarted by Guest_heydari_* , 04 Feb 2024 |
