Effect Of Operating Condition On Steam Turbine
Posted 04 December 2021 - 07:21 AM
Posted 04 December 2021 - 09:17 AM
You don't mention the outlet of the turbine.
Is it a backpressure turbine? Or does it have a condensor?
Does the vendor specify the turbine efficiency?
Find out what the outlet pressure and temperature of the turbine is during various inlet conditions.
Plot the inlet and outlet conditions on an H-S diagram (Mollier diagram)
and see on the diagram how much (if any) condensation there is
and check with vendor whether that is acceptable.
Posted 05 December 2021 - 08:10 AM
Consider this calculator to support your study .
Steam Calculators: Steam Turbine Calculator (energy.gov)
Definitely a good idea to consult the turbine manufacturer .
Posted 09 December 2021 - 10:04 PM
Sure that the efficiency and the power outlet will decrease due to the input energy reduccion. Calculate it , to figure out, I will do and let you know.
I suggest that you control the steam turbine vibrations in low inlet pressure events; depending on the mechanical design of the machinery, sometimes an unbalanced force creates vibrations due to the low inlet pressure.
Horacio
Steam AccumulatorStarted by Guest_Valeriacortez11_* , 15 Apr 2024 |
Answered
Steam Pressure Requirements For Limpet Batch ReactorStarted by Guest_golegolegole_* , 10 Apr 2024 |
How To Select Reboiler And Condenser Operating Pressures For A Mdea ReStarted by Guest_Alexis Azamar_* , 27 Mar 2024 |
Determining Operating Pressure For A Column Without CondenserStarted by Guest_phoroogh_* , 03 Feb 2024 |
