Given an initial mixture of 25 % Ethanol and 75 % Water at room temperature. I want to produce a product with an Ethanol concentration of 75%.
Batch Distillation
Posted 20 December 2021 - 12:09 AM
Posted 20 December 2021 - 01:39 AM
You do not pick the boiling temperature. The boiling temperature depends on the composition and pressure. As vapor is removed from the distillation stage, the liquid composition changes. Therefore the boiling temperature also changes continually. You can treat this system as a simple single-stage vapor/liquid flash. You just begin the boil and collect the distillate. Stop the boil when the desired concentration of collected distillate is reached. At the start of the distillation run, the vapor overhead will be higher than 75% ethanol. At the end of the batch run, the vapor overhead will be lower than 75% ethanol. Your task would seem to be to first determine the composition of the first drop of condensed vapor. What would be the composition of the vapor after 1% of the liquid were boiled away? What would be the composition at 2% and 10% and 50% and all the points in between? Add up the component flow rates of those drops over time to calculate the bulk distillate composition and total quantity. When that is determined, the batch distillation procedure would be something like: 1) charge vessel with feed, 2) boil off x% of the charge while condensing the vapor and collecting the distillate.
About 90 years ago or so, my grandfather operated his own ethanol distillery and my father helped him avoid governmental interference and deliver product to customers. I don't know if he used single-stage batch distillation, but he would have had better product yield if he had used multiple stages in his distillation.
Posted 20 December 2021 - 06:45 AM
I've attached a few documents to support your work .
