Allowable Pressure Drop Of Coldbox (Bahx)
Posted 03 February 2022 - 05:11 AM
Posted 03 February 2022 - 07:27 AM
From an energy perspective, what % of capacity is the normal situation?
Posted 03 February 2022 - 07:43 AM
Are the cryogenic exchanger designer/manufacturer and the coldbox vendor the same? If so, then they have knowledgeable support personnel who can help assess the situation and address operating issues. This equipment is customized for a particular service. Some possible reasons I see for the situation you describe: hydrates, trash in the system, equipment damage, off-design operating conditions, unreasonable vendor operating parameters.
Troubleshooting cryogenic systems can be tricky. Evaluate the whole system and not just the natural gas path. The variable pressure drop may be caused by variations in the cold streams. The process control system may be out of tune. There may be control valve problems. If you truly have hydrates build up, then fix the dryers.
Small problems in cryogenic systems can lead to permanent equipment damage if they are not resolved. Good luck.
Posted 03 February 2022 - 09:04 AM
Like any heat exchanger, a cold box is not an off-the-shelf item. It is designed and constructed by the vendor according to the specifications of the client.
The process engineer of the client has specified all the streams that enter and exit the cold box with temperatures, pressures, physical properties, duties, et cetera, and for each of those streams also an allowable pressure drop is specified. That is the pressure drop that the vendor should not exceed when designing the cold box.
In this case the vendor was apparently given a maximum allowable pressure drop of 0.4 bar, and the vendor's actual design is calculated to take only 0.3 bar (in clean condition) so that's OK.
It does not mean that the cold box will explode, or not work properly anymore if the actual pressure drop rises above 0.4 bar due to fouling or whatever.
When to clean any heat exchanger is an economical decision. Fouling costs energy and/or plant capacity.
Posted 04 February 2022 - 11:09 PM
Dear Ping Pong.
Thank you.
"When to clean any heat exchanger is an economical decision. Fouling costs energy and/or plant capacity."
My question is on this statement. When to clean BAHX? How economical aspects can affect this decision?
Posted 06 February 2022 - 05:51 AM
Severe exchanger fouling can cause increased power consumption as well as production loss.
To clean a non-spared heat exchanger the plant has to be shut down, which is production loss.
It's up to the plant manager to decide whether a shut down is more economical or not.
There is no general world wide guideline for that.
Answered
Steam Pressure Requirements For Limpet Batch ReactorStarted by Guest_golegolegole_* , 10 Apr 2024 |
Pressure Control Valve Issues For Gsw LinesStarted by Guest_fahadazh_* , 29 Mar 2024 |
Vapor PressureStarted by Guest_Hamza1111_* , 23 Mar 2024 |
Answered
Vacuum Ejector Pressure ControlStarted by Guest_himanshu.ch_* , 19 Mar 2024 |
