Heat Exchangers
Started by Jaldhipatel, Jul 16 2022 01:26 PM
Posted 16 July 2022 - 01:26 PM
Hello, 2 heat exchanger of same size put in parallel and in series which are better technically as well as commercially. Please guide as i simulated both cases, series connection showing more heat duty compared to parallel.
Posted 16 July 2022 - 04:07 PM
If you used the same design in both, it should be obvious to you that the series operation is more effective without any calculations.
Posted 16 July 2022 - 10:39 PM
Q=U*A*LMTD. The exchangers in series have higher fluid velocity which increases the heat transfer coefficient. Calculate the LMTD and the U for the exchangers in both cases and compare. Also notice the pressure drop for the exchangers in the two cases.
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
