How DEsign Flow of Pump is determined or Rated Flow also ?
Please advice on this ?
Posted 10 August 2022 - 01:43 AM
Posted 10 August 2022 - 02:52 AM
Pump rated flow is the pump design capacity and usually includes a margin, say 20%, added to the pump normal flow which is to be determined through the process heat and material balance.
Posted 10 August 2022 - 02:53 AM
Consider this link :
https://www.chemengg...google_vignette
Review in particular the specification sheet , document you should submit to vendor to get a proposal .
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
