Quick query. We have suffered from the issue of corrosion under lagging over the years and there is a proposal to remove the top lagging of certain vessels that don't require insulation from a heat loss perspective. To is to mitigate against the main cause of lagging damage to the top of vessels. The sides will be subsequently sealed.
From a fire safety perspective, is this acceptable? Does the top of vessels have to be lagged from a fire relief perspective?
Bleve potential?
The top isn't wetted so is vulnerable from that perspective but then again being the top it is unlikely to see high heat loads from a pool fire?
A top located jet fire?
The materials involved are a range of flammable liquids solvents (boiling points ranging from 40 to 130 degrees)
Any guidance much appreciated.
