Hello everbody
I have designed a PSV for fire case for a huge horizontal vessel (Vol ~ 700 m3). And for 2 phase flow I got a big PSV orifice size!
Although, we do not consider time factor while calculating the fire load but revisiting the problem revealed that it would take near about 3 hours to reach the boiling temperature !!!.
Can I just not consider the thermal expansion of liquid & leave the vapour + liquid & then vapour loads for calculating the PSV since 3 hours should be enough with adequate fire fighting to control the fire.
Pl. comment
Best Regards
Kiran
Psv Fire Case
Started by kirangparihar, Dec 15 2006 03:31 AM
No replies to this topic
Posted 15 December 2006 - 03:31 AM
Psv Fire Case Relief Load CalculationStarted by Guest_mahmooddalvi09_* , 21 Feb 2024 |
Fire Ball DistinguisherStarted by Guest_Rahimzadeh_* , 22 Dec 2023 |
Hx Psv Sizing: Tube Side Fire Case With Shell Side Being Steam.Started by Guest_tamueng_* , 07 Nov 2023 |
Kettle Reboiler Tube Rupture CaseStarted by Guest_aniljani_* , 03 Aug 2018 |
Activated Carbon Fire RiskStarted by Guest_AndyChemEng_* , 03 Aug 2023 |
