hi all,
please, i need help in understanding Flow Balancing Logic system.thanks for your cooperattion as ever.
Flow Balancing Logic System
Started by asade abiodun, Feb 12 2007 05:28 AM
Posted 12 February 2007 - 05:28 AM
Posted 12 February 2007 - 10:54 AM
So, what is it you don't understand? In what process do you want to use it, what is the problem with it, what is your background? It is very difficult to answer a question that is not specific.
I would say, the answer is 42.
Posted 13 February 2007 - 02:10 AM
Joerd,
1. What does flow-balancing logic system means?
2. It is proposed to be used in the inlet of successive filters to achieve equal flow, such that when there's low flow rate, equal distribution of fluid is maintained.
3. The problem is that i am new to the terminology and control system, i need information and logic behind its principle of operation.
4. Am a process engineer working in engineering design firm
Joerd, i hope have been able to make the information clearer.
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
Closed Drain SystemStarted by Guest_Falah_* , 26 Mar 2024 |
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
