I want to combine 2 liquid streams(pipes) at different temperatures(say 60C and 130 C) into one stream,
do I have to use the static mixer ? Or Can I directly join them together (in this case,will it cause water hammer?)
Thanks !
sfhh
Water Hammer?
Started by sfhh, Oct 30 2003 03:04 PM
Posted 30 October 2003 - 03:04 PM
Posted 05 May 2004 - 08:17 AM
Depending on the vapor pressure of the respective fluids you should be able to. Can the liquid at 60C maintain liquid state at a higher temp? Are both near their bubble point? Are you pumping the liquids or are they both flowing under the influence of gravity only?
If pumping, make sure you add valving to prevent back flow.
You don't need the static mixer just to combine two fluids together. However, if complete mixing is critical, then a static mixer should be considered.
Waste WaterStarted by Guest_refluxraider_* , 14 Apr 2024 |
Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Rapid Depressurization Of WaterStarted by Guest_golegolegole_* , 31 Mar 2024 |
Water Seal Pot Of Prv Working PrincipleStarted by Guest_panagiotis_* , 23 Feb 2024 |
Remove Water From Ammonia Aspen PlusStarted by Guest_fmalik_* , 12 Feb 2024 |
