hi guys
i am in3rd yr chemical engg. and i have this design in syllabus and i a totally confused that what should i do in this topic tand from where. if anybody have any knowledge then plz mail it to me and the design procedure also just basic:
at:
arvind.crsce543@gmail.com
Mechanical Design Of Solid Liquid Extractor
Started by Guest_arvind.che_*, May 18 2007 05:41 AM
#1 Guest_arvind.che_*
Posted 18 May 2007 - 05:41 AM
Posted 28 June 2007 - 12:10 PM
A google search solid liquid extraction turns up a number of things, one of which is:
http://www.che.boun....2/Chapter 8.pdf
Since the more common term is leaching, you might repeat the search as leaching solids The stage to stage calculations are similar to extraction, the equipment is designed to handle solids.
Rupture Disc DesignStarted by Guest_chaupradip_* , 13 Apr 2024 |
Falling Film Reactor Design CalculationStarted by Guest_Emranm02_* , 07 Apr 2024 |
Design Gauge Pressure Inlet To A Centrifugal Compressor.Started by Guest_Mohammad3799_* , 03 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
