Hi!
I made a programme to simulate thermosyphon reboiler for water. Now I would like to compare results from my simulation to real industrial reboiler. Does anyone know where to obtain data about such units?
Thanks in advance!
Reboiler Simulation
Started by Guest_majster_*, May 28 2007 04:59 AM
#1 Guest_majster_*
Posted 28 May 2007 - 04:59 AM
Posted 31 May 2007 - 09:11 AM
QUOTE (majster @ May 28 2007, 10:59 AM) <{POST_SNAPBACK}>
Hi!
Thanks in advance!
Thanks in advance!
What you're looking for is some pretty low-level info, and I don't think it's going to be publicly available. It would be coming from a DCS which would never see the light of day outside of the control room on a plant.
Perhaps you could look for some information from a university pilot-scale rig instead? There was a distillation column (or was it?) of sorts at my home town chemical engineering department (www.cheque.uq.edu.au), but it was not used very frequently.
I seem to remember that Danish Technical University (www.kt.dtu.dk) had a building (or maybe two) full of pilot-scale equipment, and this may have included a distillation column.
If you can find someone who's feeling particularly helpful (or maybe just some students who had to work on the rig), you might get some experimental data.
Good luck,
- Steve.
Ammonium Sulfate Process SimulationStarted by Guest_amir55261_* , 06 Apr 2024 |
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
Olga And Aspen Simulation SoftwareStarted by Guest_CHEMSTRONG_* , 27 Mar 2024 |
How To Select Reboiler And Condenser Operating Pressures For A Mdea ReStarted by Guest_Alexis Azamar_* , 27 Mar 2024 |
Outlet Temperautre Of ReboilerStarted by Guest_hysyshunter_* , 18 Mar 2024 |
