I want to calculate the vapour line sizing of distillation column.What formula we have to use? Can i use PM = Density x RT to findout the line sizing.Whether anyone having spreadsheet for this purpose. Please do needful.
Thanx
Bhaskaran.r
Vapour Line Sizing
Started by bhaskaran, Sep 13 2007 11:17 PM
Posted 13 September 2007 - 11:17 PM
Posted 14 September 2007 - 12:49 AM
Dear bhaskaran,
I think instead of using formula for the design of vapour line size you should click the link below. I think it would help you alot.
http://www.vatran.co...ch/NWVAPLN.html
Sarmad Nazir Ahmad
Sarmad Nazir Ahmad
#3 Guest_sunilchaudhari_*
Posted 14 September 2007 - 05:31 AM
Dear bhaskaran,
You have to design vapor size from pressure drop calculation. Minimum pressure drop is desired but it has to confirmed based on size of pipe vis a vis pressure drop available. Maximum line pressure drop has to be 10% of line pressure. For pressure drop calculation many software are available.
You can visit following site and download a limited version of software. This software is to calculate pressure drop for calculation of compressible and non compressible fluids both and gives good practical values.
http://www.pressure-drop.com/
Sunil
Sunil
Posted 14 September 2007 - 09:36 AM
Bhaskaran
Check this site could be helpfull for engineers.
http://www.mycalcula...chem/index.html
regards
regards
Posted 23 September 2007 - 07:52 AM
Bhaskaran
Line sizing has (in my opinion) two very important criteria:
1) Pressure drop : As it has already been said, maximum pressure drop should not exceed 10% of line pressure, however, this has also to be checked against the allowed pressure drop also. Allowed pressure drop is the maximum available pressure drop. Let us say, you are sizing the vapour outlet from a distillation column. It is desired to operate the top of the column at some pressure and the reflux drum at some other pressure. The difference in these pressures is the allowed pressure drop for this circuit. It is important that the line pressure drop be checked against this.
2) Velocity: Due to erosion corrosion, in some applications, then allowed velocity is restricted. some people insist on a maximum allowed vapour momentum (represent by the Fs factor). You should check this requirement also. In vacuum service, usually the velocity of vapor is quite high, and then it is important to check against sonic velocity also.
Hope this helps,
abhishek
Hope this helps,
abhishek
Posted 23 September 2007 - 12:36 PM
As i know, in compressible flow lines there is no above mentioned limitation for pressure drop, but if we want to use Darcy Equation we must follow that limitation.
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Barometric Legs Line SizingStarted by Guest_panagiotis_* , 17 Mar 2023 |
Sizing Of Vertical/horizontal Flash DrumStarted by Guest_Mohammad3799_* , 10 Mar 2024 |
Diameters Of A Structured Packing Distillation Column With No VapourStarted by Guest_hysyshunter_* , 07 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
