I would like to now if there is a good book or articles with illustrations of velocities and pressure profiles, that I may study. I mean just simple use of a ruler to check everything (10% accuracy is enough). I am looking it for 2D and 3D dimension regular channels, isotermal, steady, one phase flow of newtonian fluids. Temporary I would like to omit heat exchanging or multifacial flow problems or others some like that. Especially I hunt for transformation of the turbulent flow into the laminar. Of course I am interested in the profile of the turbulent and the laminar flows as a separate phenomenon as well. I must see all vector velocities and pressure as well. If anybody has an idea where to find the above please send me an email. I would like to skip necessity of using some fluid dynamics software due to I have no access to any right now.
2&3 D Simple Fluid Flow
Started by wiercipieta, Dec 21 2007 04:56 PM
No replies to this topic
Posted 21 December 2007 - 04:56 PM
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
