hi everyone,
I am a chemical engineering student learning how to use Hysys, i know the basic of it already but i have a question
when i already have some design on it and already the program made some calculations for me and, for example, Delete a stream. then a warning show up, but the problem after it is that even when i put the stream with all the correct conditions back, Hysys will not calculate anything more. And even worse, all the calculations already made are gone.
the only thing to get the process, or design working again is restarting Hysys and doing it again from the begining
Theres something i can do to solve this situation??
Thx everyone
Simple Hysys Question
Started by DAIALOS, Dec 21 2007 07:35 PM
Posted 21 December 2007 - 07:35 PM
Posted 22 December 2007 - 09:26 AM
Hello Daialos,
Hysys automatically solves the flowsheet environment as soon as all required input parameters are set. So, if I understood your question well (it is kind of confusing), either your solver button is put on hold or there is no sufficient information for Hysys to run.
When making those changes you described, ensure the following minimum requirements:
- Components and fluid package are chosen
- All streams and unit operations are fully specified (not underspecified or overspecified)
- Solver button is ON
Posted 22 December 2007 - 01:30 PM
QUOTE (Zauberberg @ Dec 22 2007, 09:26 AM) <{POST_SNAPBACK}>
Hello Daialos,
Thx for your message, the problem was that the solver button was on hold exactly like u said.
Thx for all
Epc Basic QuestionStarted by Guest_poojabathula369@gmail.com_* , Yesterday, 03:15 PM |
Overpressure Scenario QuestionStarted by Guest_panagiotis_* , 08 Mar 2024 |
Aspen Hysys - Creating A New Component And Defining PropertiesStarted by Guest_catiiiii_* , 22 Apr 2024 |
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
Extension Reaction Kinetic In HysysStarted by Guest_Ulbert Zsolt_* , 29 Mar 2024 |
