Dear friends,
when we simulate a packed tower by ASPEN PLUS and we use "pack sizing" feature,ASPEN must calculate "mass transfer coefficient" for sure but how can we see this value in the software?
thank you in advance for your guidance.
Mass Transfer Coefficient
Started by Guest_asad_*, Dec 31 2007 05:41 AM
#1 Guest_asad_*
Posted 31 December 2007 - 05:41 AM
Posted 31 December 2007 - 06:15 AM
HI ,. use Rate Based Fractionating column for simulation. u will get MTC in Packed size sheet.
Bye
Bye
#3 Guest_asad_*
Posted 01 January 2008 - 01:15 AM
QUOTE (Prajapati @ Dec 31 2007, 06:15 AM) <{POST_SNAPBACK}>
Bye
Bye
Dear Prajapat,
Thank you for your guidance.I did what you said but the result are several bainry MTCs. do you know how can we change them to an overall MCT ?
by the way in Diameter sheet of Fractionating column we can select " use calculated diameter" which I think it means aspen would calculate Diameter ( please correct me if i'm wrong)
but there is no value for it in the result page could you please tell me where is this value?
Thanks.
Posted 04 January 2008 - 11:12 PM
Pls go for quick column , which give you directly short cut column - or pack sizing in regular column selection you will get column dia .
#5 Guest_asad_*
Posted 06 January 2008 - 09:55 AM
QUOTE (Prajapati @ Jan 4 2008, 11:12 PM) <{POST_SNAPBACK}>
Thank you dear Prajapati.I got my answer but I think it's a littel bit illogical that we can't get all the design parameters with a single column.Radfrac is a powerful tool but it doesn't give MTC and HTC and Ratefrac don't give column diameter.but in accordance with theory both of this columns must calculate these parameters.
any way thank you for your guidance.
Coefficient Of Conversion Of Electrical Energy Into Thermal Energy ForStarted by Guest_amx_* , 03 Apr 2024 |
Mass Balance ErrorStarted by Guest_Mohammad3799_* , 19 Feb 2024 |
Operation Of Heat Exchanger Above The Overall Heat Transfer CoefficienStarted by Guest_Papps_* , 13 Jan 2024 |
Finding Catalyst Mass From GhsvStarted by Guest_daraj_* , 22 Sep 2023 |
