hello friends
i wanted to know what reactor should i use for the catalytic bed reactor in a sulphuric acid plant.and how to put the catalyst parameters.
gecian
Help On Aspen
Started by GECian, Jan 08 2008 12:50 PM
Posted 08 January 2008 - 12:50 PM
#2 Guest_asad_*
Posted 11 January 2008 - 09:04 AM
QUOTE (GECian @ Jan 8 2008, 12:50 PM) <{POST_SNAPBACK}>
hello friends
gecian
gecian
Dear GECian,
First of all we ought to know the goal of our simulation. in a sulfuric acid plant design the designer company is not responsible for catalyst quality. they just order to catalyst producers and the producers must gauranty the quality of the catalyst and also some necessary parameters like pressure drop and persentage of conversions in beds. in this point of view catalyst parameters for a catalyst bed in sulfuric acid plant are diffrent according to their producers and also catalyst's types. catalyst producers don't reveal these parameters because it's their know how.
So as a designer you should calculate the necessary pressure drop and also conversion% in each converter bed and ask a catalyst producer company like BASF or Monsanto to gauranty them.for these calculation you can use a stoichiometric reactor in aspen plus.
I hope this can help you.
ASAD
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
Olga And Aspen Simulation SoftwareStarted by Guest_CHEMSTRONG_* , 27 Mar 2024 |
Answered
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Aspen Custom Model Won't Load Into HysysStarted by Guest_SaintLazarus_* , 21 Mar 2024 |
Aspen Hysys SimulationStarted by Guest_amazingspidermean_* , 18 Mar 2024 |
