If any design engineer can palce the formula for sizing a flash drum to seperate urea solution and gases. Is gas-liquid kock out drum sizing formula can be applied to it wherein terminal velocity is calculated and based on it vessel is sized. What sould be the droplet sixe is taken for urea if the same formula is applied.
Urea Solution Flash Drum Sizing
Started by aminmeo, Jan 10 2008 12:49 PM
Posted 10 January 2008 - 12:49 PM
Posted 14 January 2008 - 11:34 AM
Your poor grammar and spelling make it difficult to understand your question. Use the Brown-Sauders Equation for determining the diameter needed for a vertical gas-liquid K.O. Drum. You do not need a droplet size for this calculation.
Doug
Doug
Sizing Of Vertical/horizontal Flash DrumStarted by Guest_Mohammad3799_* , 10 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
Ro SizingStarted by Guest_T_bag_* , 27 Feb 2024 |
Vent Sizing Using GooseneckStarted by Guest_mychemicalromance0425_* , 23 Feb 2024 |
Answered
Nozzle Sizing CalculationStarted by Guest_BabRafiq1_* , 26 Aug 2022 |
