Good evening,
Is it possible to transfer stream compositions and properties from Hysys to Aspen Hetran (B-JAC module), and if yes, how this can be done? Or, if direct data transfer is impossible, what other procedures are available (doing it through AspenPlus, perhaps)?
Aspen Hetran doesn't look so much user-oriented like Hysys and defining inlet and outlet stream from heat exchanger seems to be a task where it is very easy to make a mistake.
Thanks in advance,
Aspen Data Interchange
Started by Zauberberg, Jan 21 2008 09:56 AM
No replies to this topic
Posted 21 January 2008 - 09:56 AM
Aspen Hysys - Creating A New Component And Defining PropertiesStarted by Guest_catiiiii_* , 22 Apr 2024 |
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
Olga And Aspen Simulation SoftwareStarted by Guest_CHEMSTRONG_* , 27 Mar 2024 |
Answered
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Aspen Custom Model Won't Load Into HysysStarted by Guest_SaintLazarus_* , 21 Mar 2024 |
