Gentleman,
In Hysis how to get the details of % flooding and % downcomer back up from the tray loadings details.Pl. tell me the route of getting the details.
mosa
Hysis Simulation
Started by mosa, Feb 09 2008 01:47 AM
Posted 09 February 2008 - 01:47 AM
Posted 09 February 2008 - 06:48 AM
QUOTE (mosa @ Feb 9 2008, 12:17 PM) <{POST_SNAPBACK}>
Gentleman,
mosa
mosa
Dear you can try in the tray sizing utility. Go to tools-- select tray sizing utility ----click on add utility------------tray sizing utility will be added...................click on the added tray sizing utility and the click on view button..............select the column tray section you awnt to either design or rate--------------in the spec type you can change rating form desig and give the actual inputs of the existing tower and check in the performance tab................for the results.
Ammonium Sulfate Process SimulationStarted by Guest_amir55261_* , 06 Apr 2024 |
Olga And Aspen Simulation SoftwareStarted by Guest_CHEMSTRONG_* , 27 Mar 2024 |
Aspen Hysys SimulationStarted by Guest_amazingspidermean_* , 18 Mar 2024 |
Linear Alkyl Benzene Sulfonic Acid Production (Labsa) SimulationStarted by Guest_Emranm02_* , 03 Mar 2024 |
Stabilizer SimulationStarted by Guest_prashant.badgujar_* , 02 Feb 2024 |
