Hi all,
I am trying to use hysys 3.2 for viscosity calculations in a two phase system. Can anyone help me with the packages and column to be used? I work with 3 component-two phase systems and in one of the articles I read that equilbrium column should be used, but I could not find it, can it be missing in Hysys3.2?
Hysys 3.2 For Viscosity Calculations
Started by goekche, Apr 01 2008 06:41 AM
Posted 01 April 2008 - 06:41 AM
Posted 09 April 2008 - 06:35 PM
Can you describe your case in more details? I'm not sure what are you refering to, and what could be the problem with "columns and packages". Viscosity of process streams (and phases) is always given as tabular value in the stream "Properties" tab.
Now, viscosities (and physical properties in general) predicted by Hysys are very often out of order, but that is another story.
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
Extension Reaction Kinetic In HysysStarted by Guest_Ulbert Zsolt_* , 29 Mar 2024 |
Aspen Custom Model Won't Load Into HysysStarted by Guest_SaintLazarus_* , 21 Mar 2024 |
Aspen Hysys SimulationStarted by Guest_amazingspidermean_* , 18 Mar 2024 |
Using Vector User Variable In HysysStarted by Guest_Ulbert Zsolt_* , 01 Mar 2024 |
