what can be the maximum value of Cd drag coefficient in determining the terminal velocity in separators?
Maximum Value Of Cd
Started by kumarnagarathinam, Apr 21 2008 12:34 AM
Posted 21 April 2008 - 12:34 AM
Posted 22 April 2008 - 03:06 AM
drag coefficient depends on the flow regime... for laminar is 24/Re (Stokes regime), but if the droplets/particles are very small Cunningham correction should be accounted for... for intermediate (Allen) there are some relations where CD is proportional to Re^-0.6... for turbulent (Newton) regime CD takes the constant value 0.44... but this is ideal situation and true when droplets or particles are perfectly spherical (in the case of solid particle vary rare, in the case of droplets if they are relatively small and are not deformed and behave like a rigid body)... one of relations which includes shape factor (sphericity) was proposed by Haider and Levenspiel...
however, to be honest for separators a simple Stokes relation is commonly used as the droplet size and fluid properties are such that Re is usually < 1
Maximum Nozzle Size In The Api 650 TankStarted by Guest_rudiawan_* , 18 Oct 2023 |
Maximum Number Of Regeneration Cycles In Mole SieveStarted by Guest_YouAB_* , 23 Apr 2023 |
Maximum Inflow To Sourwater Feed Preparation TankStarted by Guest_Francis philomenraj_* , 23 Feb 2023 |
Maximum Vessel Wall Temperature For Fire (Gas Expansion) CaseStarted by Guest_yog123_* , 14 Dec 2022 |
Maximum Allowable Concentration Of H2SStarted by Guest_z_z_* , 16 Sep 2022 |
