Please, I ask about RVP (Reid vapor pressure) in HYSYS. How can i obtain a RVP for a Stream at 90 °F or any other temperature? Because Hysys calculate a RVP at fixed temperature 37.7 °C.
Thanks.
Hysys Rvp
Started by Omar79, May 14 2008 07:26 AM
Posted 14 May 2008 - 07:26 AM
Posted 14 May 2008 - 09:22 AM
You can do a trick and use heater/cooler unit operation, with process stream outlet parameters set as:
- Vapor fraction = 0
- Temperature = 90F
HYSYS will give you the pressure at which process stream is at its bubble point. If you are constrained by RVP value at 90F (by modifying upstream equipment operating parameters), then the bubble point pressure of your stream should not exceed the bubble point pressure calculated by HYSYS at given temperature.
- Temperature = 90F
Posted 14 May 2008 - 10:02 AM
That is right for TVP (total vapor pressure). RVP as defined per ASTM D323 is always at 100F (37.8C).
http://www.astm.org/Standards/D323.htm
RVP is related to TVP, and often used to limit the vapor pressure of the product, so that it can be stored in an atmospheric tank. So, Omar, can you go back and see if you need RVP (i.e. at 100F) or TVP at 90F?
Posted 14 May 2008 - 10:09 AM
Dear;
How it could be the RVP as there are different methods to calculate the RVP(API and ASTM) but its always at 37.8 C.
We can use the correlation for properties selecting the Refinery and you will find RVP else you could have it with Cold Property Utility.
The best approach to get the RVP is to get it from the RVP Extension which is available free on the aspen tech support website.
Aspen Hysys - Creating A New Component And Defining PropertiesStarted by Guest_catiiiii_* , 22 Apr 2024 |
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
Extension Reaction Kinetic In HysysStarted by Guest_Ulbert Zsolt_* , 29 Mar 2024 |
Aspen Custom Model Won't Load Into HysysStarted by Guest_SaintLazarus_* , 21 Mar 2024 |
Aspen Hysys SimulationStarted by Guest_amazingspidermean_* , 18 Mar 2024 |
