Sirs,
Can any body sujjest me the suitable procedure of converting commercial phosphoric acid in to edible phoshoric acid 300TPA (small scale or medium scale production).
My contact mail address is kkrao22@hotmail.com
Thanks.
Phosphoric Acid
Started by Kameswara Rao, Mar 28 2004 07:23 AM
Posted 28 March 2004 - 07:23 AM
Posted 29 March 2004 - 10:51 PM
While I'm not expert on the process, all of the food grade phosphoric acid plant that I've visited were designed to do just that.....make food grade phosphoric acid. I'm not familiar with any plants where the plant was converted from industrial grade acid to food grade acid.
I do know that Jacobs Engineering is well versed on the topic.
Guest_Guest_*
Posted 25 April 2004 - 08:53 AM
Sirs,
If not from commercial acid, atleast what is the process for manufacturing food grade Phos. Acid.
can you sggest me any refence plant to contact.
Thank you.
kkrao22@hotmail.com
Thank you.
kkrao22@hotmail.com
Convertor Performance For Sulphuric Acid GenerationStarted by Guest_Ranga v_* , 01 Jun 2026 |
Sulfuric Acid Plant Aspen Hysys HelpStarted by Guest_kazuki222_* , 29 Apr 2026 |
Heat Of Dilution Of Hydrogen Chloride In Hydrochloric Acid Solution (3Started by Guest_fredlan54_* , 21 Nov 2025 |
Phosphoric Acid 56% Tank LiningStarted by Guest_Phosphoric123_* , 20 Apr 2025 |
