I want to do a simple simulation in HYSYS
Inlet steam specification:
Steam
Temp- 385 C
Pressure: 45.9 kg/cm2 g
Flow rate : 50 te/hr
Valve opening: 50 %
Outlet :
steam
Pressure- 4.1 kg/cm2 g
Temp- Predicted by HYSYS
the valve is a Pressure control valve controlling Pressure of Output stream at 4.1 kg/cm2 g
I want to know if the valve gets 70 % open what will be the pressure & temp downstream
Simple Simulation
Started by ayan_dg, Jul 14 2008 01:36 AM
Posted 14 July 2008 - 01:36 AM
Posted 14 July 2008 - 07:36 AM
I'm not sure if I understood your question in a correct manner, but here is what will happen if we are thinking about the same thing: pressure downstream of control valve is unchanged, and higher valve opening is just a consequence of increased steam demand. Therefore, resulting temperature will be the same as in 50% valve opening case - simply calculated by isenthalpic flash - as long as both pressures upstream and donwstream of control valve are unchanged. Is that your query?
Posted 14 July 2008 - 10:53 PM
QUOTE (Zauberberg @ Jul 14 2008, 07:36 AM) <{POST_SNAPBACK}>
Actually what i intend to simulate is what will happen downstream if Automatic control of pressure is lost and the valve inadvertantly open fully.
Posted 15 July 2008 - 09:25 AM
Dear,
As far as Hysys Dynamics is concerned Hysys recommends you to specify the P-F dynamic specication i.e. pressure-flow relationship. So once you put your controller in manual mode of operation and give the manual output the result will be varied flow based on the Cv calculated in the Dynamics tab of the Valve operations based on the user inputs options. It keeps the discharge presure constant. I hope this will clear your doubt. Waiting for your comment.
In Dynamics you cannot specify flow in your case its 50000 in case of P-F specifications. What you can do is specify the flow in order to intialize the stream and once you switch to dynamics flow will ba calculated accoring to the Control valve Opening its Cv and all.
Ammonium Sulfate Process SimulationStarted by Guest_amir55261_* , 06 Apr 2024 |
Olga And Aspen Simulation SoftwareStarted by Guest_CHEMSTRONG_* , 27 Mar 2024 |
Aspen Hysys SimulationStarted by Guest_amazingspidermean_* , 18 Mar 2024 |
Linear Alkyl Benzene Sulfonic Acid Production (Labsa) SimulationStarted by Guest_Emranm02_* , 03 Mar 2024 |
Stabilizer SimulationStarted by Guest_prashant.badgujar_* , 02 Feb 2024 |
