I'm a MSc student and I try to simulate a biodiesel process production in Aspen Plus. I don't use HYSYS due to the lack of its library in data. I have a stream containing a fatty acid ester, a triglyceride and sulfuric acid. As you may know, I can't use a distillation column for this separation, because the bottom stream's temperature will rise and it will break the fatty acid chain. So, I tried to use an extraction column using as solvent water, glycerol but I can't find the solution. I tried many models to simulate.
What do you propose about this?
Thank you very much in advance.
Separation Esters From Sulfuric Acid
Started by Constantinos, Sep 13 2008 09:16 AM
No replies to this topic
Posted 13 September 2008 - 09:16 AM
Separation Of Ethyl Acetate And IpaStarted by Guest_Jaiganesh_* , 14 Apr 2024 |
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
Sulfuric Acid PlantStarted by Guest_Kartik54_* , 16 Mar 2024 |
Linear Alkyl Benzene Sulfonic Acid Production (Labsa) SimulationStarted by Guest_Emranm02_* , 03 Mar 2024 |
Answered
Different Separation TechnologiesStarted by Guest_hysyshunter_* , 27 Feb 2024 |
