What are the types and components of lubricating oil.I am aware that there are also different grades of lubricating oil.Can I know how it could be analysed.A recommended site for further study shall be appreciated.
Analysis Of Lubricating Oil
Started by ukpeters, May 14 2003 08:01 PM
Posted 14 May 2003 - 08:01 PM
Posted 15 May 2003 - 01:47 PM
Ukpeters:
Each manufacturer of lubricating oils very probably uses their own proprietary "recipe" and each grade will also have a different recipe ... so I don't think there is any way to generalize the components in lubricating oil.
However, each grade has a set of mandated properties such as flash point, viscosity, etc. Those properties and how to test for each of them is available from the Society of Automotive Engineers (SAE). You can contact them at www.sae.org
Posted 16 May 2003 - 11:56 PM
Thank you so much.That was a bit helpful though the site you referred me to didn't have much on the topic.Actually I am interested in the composition of the most standard grade of lubricating oil and its analysis.If you have info on this please do share it with me.Thanks once again.
Aspen Plus - Sensitivity Analysis / Case Study - Need AssistanceStarted by Guest_SickPuppy0_* , 07 Feb 2023 |
Answered
Exergy And Sustainability Analysis Of Batch Distillation Of OilStarted by Guest_waheed2020_* , 24 Jan 2022 |
Data Plant Stability AnalysisStarted by Guest_A_D_M_MII_* , 21 Jul 2021 |
Books For Coupling Thermal And Chemical Analysis Of Different ChemicalStarted by Guest_Obiwan1997_* , 14 May 2021 |
Analysis Of Reduced CrudeStarted by Guest_engeng_* , 11 Feb 2021 |
