International Standard Index List
#1 papaya
papaya
  • 36 posts
Posted 04 February 2009 - 02:56 AM
hi guys, I need help finding index for International Standards that contains the Document Number and Title so I know which document is relevant to the equipment I'm doing.
I have access to multiple (but not 100%) standards like IEC, IEE, API, ASME, ASTM, BS, IP, ISO etc but they are named with document number only so it is quite impossible for me to go tru each document to check their contents (approx 10GB of standards...). I cannot find any index regarding these standards so unless the person is very experienced or the specification ask us to refer to the number it is very difficult to find out which standard needs to be used.
And since I don't have 100% complete standard it would be helpful to have an index for each standard so i can request purchase of the standard when I look at the index and notice it's not available in our library.
So if anybody come across any index for any international standards please post them out so everybody benefits.
Thanks in advance!
#2 kimo
kimo
  • 6 posts
Posted 04 February 2009 - 02:20 PM
hi their,
it is very simple. do your own search on line for the respective code in question. then when you get the home web site , click on catalogues/documents/index etc and you will recieve all their listed docs/indexes/catalogues with titles etc
you may get also some other vendors web sites (during your search) that can brovide
you with same results.
regards
kimo
#3 hamadzzz
hamadzzz
  • 22 posts
Posted 07 February 2009 - 06:03 AM
QUOTE (kimo @ Feb 4 2009, 10:20 PM) <{POST_SNAPBACK}>
hi their,
regards
kimo
thanks all ,
dear kimo if you have it pls share it with us ,
tanks for you
Thanks in advance
HGA
#4 kimo
kimo
  • 6 posts
Posted 07 February 2009 - 02:13 PM
QUOTE (hamadzzz @ Feb 7 2009, 06:03 AM) <{POST_SNAPBACK}>
hi their,
regards
kimo
thanks all ,
tanks for you
Thanks in advance
HGA
hga
you have to specify your problem first. do you want to design/specify/construct..etc a piece of
equipment ( boiler & pressure vessels, rotating equipment..and for what industry/services.. ) . there are specific codes for every single piece of equipment ,example : centrifugal/reciprocating pumps; compressors; fans; turbines;atm. tanks/pressure vessels, above ground/underground tanks, heat heat exchenger; etc . to have an excess for each , you have to be a member or buy/or pay for respective document . so let me know what is your problem?
thanks
kimo
