Hi:
Could I use HYSIS FOR producing polypropylene pellets!!!!???
If not is there any other programmes to calculate the all parameters used during the production of propylene liquid to polypropylene pellets!!?
thanks
Hysis (L,g,but Not Solid)
Started by betty, Feb 09 2010 11:33 AM
Posted 09 February 2010 - 11:33 AM
Posted 10 February 2010 - 06:41 AM
no replay!!!
Posted 10 February 2010 - 11:51 PM
The short answer is no. The cynical answer is; Hysys does not produce PP pellets. The honest answer is that this process is mostly a heat transfer problem with discrete solid particles. Dependent on your needs you could use shortcut sizing methods, by hand or on a spreadsheet, all the way up to a complex CFD model. I don't know if there is any commercially available specialized software to model this process, unfortunately. Good luck with your search.
Equilibrium Vapor Liquid Solid In Trickle Bed ReactorStarted by Guest_nannanine_* , 14 Dec 2023 |
Solid Naoh Dissolving In WaterStarted by Guest_lak1r_* , 10 Apr 2023 |
Solid Entrainment In Vapor StreamStarted by Guest_Leotop_* , 16 Feb 2023 |
Hysis Vba Mixed Liquid Phase Data AccessStarted by Guest_Jose123123_* , 27 Dec 2022 |
At What Temperature Does Water Evaporate When Drying A Solid ?Started by Guest_Checster_* , 30 Nov 2022 |
