Can any one help me:
Do we need to install vortex breakers, if outlet nozzle (10") on a conical potable water tank (2000 m3) is on side. Pumping capacity is 110 m3/hr.
Vortex Breaker-side Outlet Of A Tank
Started by vvsastry66, May 11 2008 07:35 AM
7 replies to this topic
Posted 11 May 2008 - 07:35 AM
Posted 12 May 2008 - 03:04 PM
QUOTE (vvsastry66 @ May 11 2008, 03:35 AM) <{POST_SNAPBACK}>
Do we need to install vortex breakers, if outlet nozzle on a conical potable water tank is on side.
If you don't mind sucking air into your pump suction, then you don't need a vortex breaker. Alternately, if you can guarantee that the liquid level will always be sufficient so that a vortex that reaches the outlet nozzle is not possible, then you can dispense with the V.B. Else, you should install one.
To check the criteria for self venting flow to see if situation #2 applies, YOU will need to search the internet or other references to find the applicable formulae. Then you can determine the minimum liquid level you will need. (Practically speaking, a V.B. is simple and inexpensive, and I fail to see why you would NOT want to install one. They may be used for bottom OR side OR top outlets.)
Posted 28 May 2009 - 12:20 PM
Posted 07 June 2009 - 06:35 PM
Posted 12 June 2009 - 12:26 AM
Posted 16 June 2009 - 11:22 AM
Art has given a few excellent comments and links on gravity and self-venting flow at Eng-Tips: http://www.eng-tips....d.cfm?qid=87442
I belive the spreadsheet he had made for that purpose should be available at ChE forums as well. Try using the "Search" engine.
![]() Free Vent For Api 650 Tank - Bug Screen / Bird Screen RequirementStarted by Guest_Cabbarbeybaba_* , 03 Jul 2025 |
Steam On Shell Side Of A Vertical HexStarted by Guest_Lyne_* , 09 Jul 2025 |
