What is the purpose of trim duty when trying to solve a column in HYSYS
Cdu Simulation
Started by Clayton, Oct 24 2008 12:03 PM
Posted 24 October 2008 - 12:03 PM
Posted 27 October 2008 - 02:15 AM
How you came across the word "trim duty" ? From HYSYS or TEXT (and what is it ?)
"Trim duty" in common engineering term mean "remove unnecessary duty"
Posted 27 October 2008 - 02:45 PM
Trim Duty was the term i took form the hysys refining tutorial. It was also refered to as Q-trim and it is linked to the column as an energy stream. I don't know what the purpose of it is just that i think it adds another degree of freedom to the column
Posted 21 November 2008 - 08:55 PM
This duty stream is there to offset the energy balance and faster converge the column, usually in curde column (heavy streams). Ideally you should once the column is solved identify how to correct the energy balance and minimise or remove the trim duty stream.
When dealing with heavy streams this could be a major issue as plant data and simulation energy may not prefectly match. The trim duty stream helps alot
Cheers,
SM
Cheers,
SM
Posted 21 November 2008 - 09:44 PM
This was very helpful
Thankyou
Thankyou
Simulation Of Natural Gas Water Dew PointStarted by Guest_guoyinyanliner_* , 03 Nov 2025 |
Static Simulation Of An Atmospheric CduStarted by Guest_tomr91_* , 10 Aug 2025 |
Syngas Plant SimulationStarted by Guest_kaidlut_* , 28 Jun 2025 |
