Recently I faced a headache problem when I realized I do not have sufficient hydraulic / static head to overcome piping frictions loss from the liquid outlet (Test Separator) up to the inlet of Coriolis meter / Mass flow meter from Emerson/Fisher Valve.
One of the requirement of Coriolis meter is it is designed for single phase liquid and accuracy will affected if partial vapor or flashing occur. The accuracy of this type meter is 0.2% mass flow.
I'm facing problem because the liquid inlet to Coriolis meter (after a Y-STrainer) indicate vapor faction of 0.0002 or 0.64kg/hr vapor/gas generate.
Attached please find my HYSIS files, I had done the hydraulic checking using PIPE Segment in HYSIS and also I compare with may manual calc (Both are tally)
Basic data input in Calc:
a) Static Elevation head available, measured from LL of Test Separator at 0.2m to the centre line of meter is 0.758m or 0.0555 Bar Static pressure available (Using ^ P = density x 9.81 x Head in meter / 100,000 to get Bar)
c) Total equivalent lenght of all fittings (90 Elbow, Strainer, reducer...etc) = 40m
HYSIS and hand calc / noth shown that pressure drop across the line >> Static head available
Hence, partical flashing of vapor fraction = 0.0002 is expected.
Refer to my HYSIS attachement.
My question here:
a) Any experience Instrument guy can help me on this?
I'm pushing the client / plant owner to rellocate the meter, at least provide 2 m static head but they are so stubborn and afraid to change. (I see what can I do here.... something changing people mindset is very very difficult .....)
Hope you guy can help
